antijam
- Jul 20, 2008
- Location
- Gloucestershire
- 2003 SLK320
My SLK320 has been laid up for more than a year and now won't start. Initially it restarted on the first turn of the key but has gradually become more difficult. Some mornings it would not start and other times it would without problem. Turning the key now displays a full complement of dash errors and the shift is locked in Park but the starter is not engaged - there is not even a click from the solenoid.
One obvious culprit could be the K40 relay, and I have removed, disassembled and inspected this.
I have checked the fuses, cleaned the relay contacts and there don't appear to be any dry or damaged solder joints and I'm wondering if there are any simple tests using a multi-meter that can be done to check functionality? Any help would be appreciated.
