Malcolm Johnson
- Jan 27, 2006
- Location
- East Yorkshire & Suffolk
- R230 (M273) & W221 S350 bluetec
A question re the SL, when the starter Battery is holding 12.55 volts after several days of non driving. Starts perfectly from cold (instantly) but if started when warm, Starter motor turns at same speed as cold then eventually starts with a tap of the go pedal. But if cooled down say 45 mins, Starts fine. This is very reminiscent of my two pot mottoguzzi which did not like warm starting and eventually I tracked it down to the solenoid not pulling in within the starter motor. Guzzi stealership took the money for investigation and alleged bad connection at a relay base. Totally wrong. Sorted myself for £29.75, fiat solenoid. My thoughts at the moment is possible resistance temperature issue. Any thoughts much appreciated a i don't think this is a specific SL issue. More a aging circuitry/part issue.
As I say any thoughts are helpful.
