Steering is doing my head in
Aedmer
2013 C220 CDI AMG (line) Sport BlueEFFICIENCY Estate
Hi all, never posted before.
I have a 2013 W204 C220 CDI Estate. When I first got it around a year ago steering was fine. Had the car about 18 months now and the steering drives me mad.
At low speeds the steering feels heavier than normal sometimes, then other times will loosen up. Could be an issue with the speed sensitive steering maybe? As well as that, sometimes when I slow down coming up to say a roundabout, the steering wheel will 'stick' when I turn it like I have to push past this sticky point before I can go on turning the wheel. It's bizarre. Indy had a look at the power steering pump n said no issues. Another indy drove the car and said the steering feels fine??? It doesn't steer the same as it did 18 months ago so how is it fine?
I'm at my wits end. Any ideas? Sorry for the huge rant.
Sent from my SM-N950F using Tapatalk
Craiglxviii
Cambs UK
Steering rack failure it could be...
Aedmer
Aedmer
I thought that but the wheel isn't madly tight like i've lost power steering. Just different to how it was. It's been this way about 8 months so surely it would have worsened by now? No grinding noises, no smells and no leaking power steering fluid.
Craiglxviii
Cambs UK
The way that some racks can fail give symptoms exactly as you describe, where there’s a “sticky point” just before the wheel “gives” as you apply the turning moment with your hands.
Aedmer
Aedmer
Hmmm that's not good. New rack will run me about 3 bills I think with my indy
Craiglxviii
Cambs UK
Where are you based?
Craiglxviii
Cambs UK
By the way, there are about 25 different steering racks for your car. A quick google search of the first 3 part numbers listed gives online pricing between £350-500.
joderest
ML270 2003
Just a thought, have you had tracking/alignment checked to make sure all good, and have you had a good look at front tyres.
Aedmer
Aedmer
I had a 4 wheel alignment about 30 mins ago haha and no difference. Front tyres fine.
Aedmer
Aedmer
Sorry if already mentioned, but have you checked the power steering fluid level?
Indy did at service in early september, no issues.
V6Matty
Newark, Nottinghamshire
Did any of the Indy’s do a live data reading while driving to ensure things are reporting as they should be, speed sensors will give false readings and the speed sensitive steering will be affected by this
Aedmer
Aedmer
Matter of fact they didn't. Thanks for this, got my main guy comin in a couple of days I'll ask him to do this
DeeEmm
Bury,Lancs
C220 CDI ESTATE 2012
I would try a full diagnostic check up, more likely to be a sensor if the problem is intermittent.
