EddieB
Hello All
I have a problem with my 1997 SLK 230K's steering. It is nothing too drastic, it is just a bit vague. It seems to wander around when crawling along slowly. It generally pull whichever way the camber is on the road - so usually to the left though not always (if you find yourself on an opposite camber it goes away). Occasionally, a bit of free play appears on the steering wheel - about 1" - when sitting at lights or a junction.
The brakes are new, the wheels and tyres are new, the tracking has been checked and double checked. I can only think it is a steering problem (am open to suggestion on this).
A local garage had a look at it and thought the steering rack was the fault, though they couldn't promise that would cure the problem (or was even the only problem) and suggested a Mercedes Specialist.
Does anyone have any idea what the problem may be? I don't have the time to do the work myself so would appreciate any recommendations you have about a good Merc Specialist, ideally local to Walthamstow in East London (happy to consider North London and as far as Essex if the car will be well looked after).
