Steering rack 'play'
Status
Not open for further replies.
Messa
Wigan
E220CDi
Had my C250TD '99 96k in for a service/MOT today and they have advised me that although it isn't a fail, i have got play in the steering rack.
Has anyone any experience of this, and any clue to cost to get fixed?
Also, is it something i need to worry about or can i safely wait until next MOT ?
Thanks,
Neil
PS. I had actually noticed a slow speed 'clunk' on steering/going over bumps previously, if anyone else has those symptoms
230K
Belfast
E300TD/1998/3.0 Diesel
You do not have a steering rack, your car has a steering box.
If the MOT centre knows so little they are probably referring to the play that all MB models with a steering box have when they are not pointing straight ahead.
230K
piestore
manchester
steering rack
Hi Messa
have to agree with 230K you don't have a steering rack if its passed and it drives OK don't bother , slow speed clonk sounds like bottom ball joints
jberks
If I remember correctly, steering box can be adjusted to remove the play. Did it on an 280E (w123) and it made a massive difference. I believe its just a case of tightening a bolt, but I'll leave it to the experts to advise.
M
Messa
Wigan
E220CDi
I have mistakenly said rack, but it does say box on my sheet sorry.I am still living in old money, but thanks for the advice fellas.
I would be intrested to hear more about the adjustment if anyone has more info (thanks jberks).
cheers,
Neil
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hi Neil.
wouldnt be an expert either but on top of the steering box there is a threaded bolt with a slot for a screwdriver which has a lock nut attached. It is adjusted by loosening the locknut and screwing down the bolt with a screw driver until play has been taken up, then locked by the nut. This usually takes up a bit of play but not always enough. Do not overtighten the the bolt, causes stiffness in steering and not good for the box either.
All of the above refers to a 123 series.
Regards
Mike
Arnie
London
Messa, actually, saying "rack" is new money...!
I think the said bolt is unscrewed to tighten up the play (??), but do it in the straight-ahead position, as this is where it is designed to have minimum play. If you tighten too much, you can jam the gears and beware that disturbing the mechanism to much can cause old oil-seels to leek, which becomes a particular problem with power-steering.
Status
