Steering Rack rebuild / reconditioned rack ?
MarkyG
Surrey
C350 Coupe
I have a low mileage c203 350 with a steering rack problem. Noisey when going over uneven road surface, banging and clunking sounds from the drivers side. Arms, inner/outer tie rods, ball joints all good.
Can anyone recommend a reconditioner or where I can get hold of one.
Or does anyone have a good used one for sale ?
ECP and CP4less used to have them but no more :(
A2034603600 with option 213-Speed-sensitive power steering/Vario steering
Steve@Avantgarde
Bristol/Somerset
Highly unusual for a rack to fail, are you sure the torsion control arm bushes haven't failed? Top suspension mounts are also usually the issue.
Worked on thousands of 203s, I've never replaced a rack on one.
Steve@Avantgarde
Bristol/Somerset
Fair enough. I can't cast any dispersions on someones opinion without seeing the car, I just can't say I've ever had a problem with a steering rack on a 203 but I have had plenty of issues with arms, bushes and mounts that cause all manner of steering issues...
bertb1
C220 amp sport 2013
I’m have a similar problem
Had a slight knock on the passenger side
Took the car in and was told both arms need replacing
Had the arms changed on both front wheels
Now I’ve got a worst knock on the drivers side but the garage is saying nothing wrong
I think something not been tightened enough
I’m back a the garage later
M
MarkyG
Surrey
C350 Coupe
I was just looking at your website to see whereabouts you're located as a possible 2nd opinion.
Happened to look at your price list for SLR McLaren spark plug change :eek::eek::eek: £10k !
Is that an engine out job ?
V6Matty
Newark, Nottinghamshire
S212/10/E350(His) W169/2005/A180 (Hers)
Could by the top mount for the shock absorber or the shock on its way out
bertb1
C220 amp sport 2013
Well I had no luck
The garage are still saying nothings wrong
Getting a second opinion on Saturday
bertb1
C220 amp sport 2013
Update
Second option still can’t find anything wrong
He says he can hear the noise / clunking but all appears tights and correct but he assured me it’s not the steering rack
He say could be e drop link but not sure
Basically wait until it gets worse
malcolm210
Drop links are notorious for knocking when worn easy to change and cheap to purchase so well worth considering doing
I remember a knock on a car I couldn’t find it was driving me mad, wasn’t the rack or any part of the suspension turned out to be an engine mount in the end
Steve@Avantgarde
Bristol/Somerset
Im in Clevedon, J20 of the M5 just outside Bristol.
Yes its engine out to change the plugs!
Frontstep
T210 320cdi
£10,000 hmm I know someone with one of those who isn't the nicest person in the world
