sterering vibration
malcolm e220
new member here would like some help:i have an e220 coupe and recently noticed that at 50 mph steering wheel starts to vibrate:getting more violent at higher speeds: i,ve had my wheels balanced 20 gramms each wheel:and my tracking is spot on according to the garage: any advice ps not very mechanically minded regarding cars
tom7035
Welcome to the forum Malcolm.
In order of ease and cheapest first, I would have the balance redone by another firm and try it again. If this doesn't cure your problem, have the steering damper checked and replaced if necessary - not difficult or too expensive. If neither of these are successful then the drag link/idler arm balljoints or track rod ends need to be looked at. (Any outfit worth their salt though I would have expected to check these before doing the tracking). Neither is this job too complicated, any non-franchised garage could do it.
HTH, Tom.
M
malcolm e220
steering vibration
thanks a lot for the reply have taken notes and will be off to the garage to have said points looked at:cheers much appreciated
M
malcolm e220
steering vibration
Just one more point i forgot.Recently drove to manchester when i noticed the vibration also noticed car appears to drift to the left and you have to only slightly adjust steering to go in straight line:hence why i thought tracking:as previously stated subsequent laser testing of wheel alignment came back as all clear this left me puzzled:any ideas many thanks
tom7035
Re. drifting left, any car properly 'specced' in terms of tracking, matching tyres both sides and inflated correctly, should have a slight tendency to drift left simply owing to road camber. There has been much discussion on the forum about this and it seems MB are particularly prone. If only slight, treat as normal. If you ever get the chance for a moment or three try driving on the 'wrong' side where there's a camber - the opposite should be the case, or, alternatively, straddle the centre of the road, when it should go straight!
Don't forget to post final results, so others may benefit.
M
malcolm e220
steering vibration
Many thanks:all sounds so logical now!, will post results in the very near future.Once again many thanks
M
malcolm e220
steering vibration
Just to update the forum.Took car out for a spin and tried driving on wrong side of road(taking great care to notice no police or general public around).The car pulled to the right just as you suggested.Then drove down the middle and it drove straight as an arrow.Thank you once again,still have not been to garage yet to hve have vibration looked at funds not yet available but will be going in soon and will be sure to post results as soon as posible.
