Sterio swap....advice
malty123
Nottingham
E350cdi sport 2011
Looking to sawp my dated Blaupunkt (with pixels missing from the display) radio casette head unit for a more modern unit, but i would like to keep the current cd changer that is in the boot...
question is, will a more modern head unit be compatable with the current cd changer?
thanks
Need some dates, etc and what the car is,, these things differ by year
SQ_W211
W219 CLS55 AMG
thanks
If you buy aftermarket stereo, it will be hard to find any that will be compatible with your current CD changer. If you are looking to buy new stereo, buy one with USB adaptor which will then allow you to put all your songs on the USB stick rather than worry about CDS. Also aftermarket stereos will also require steering wheel interface to allow the volume control on steering to work
malty123
Nottingham
E350cdi sport 2011
sorry is the 1996 sl320
The one with the roof ecu in for a fix, thought i would play with a few other bits whilst its out of action:p
brandwooddixon
Wolverhampton
S63 Coupe 2014
It is possible that it may do so, but an adapter may be required interface between the new unit and the old changer.
Have a look here: http://www.bluespot.co.uk/
I have used them twice in the past and have found them helpful in this regard.
malty123
Nottingham
E350cdi sport 2011
was looking at one of the all in one cd dvd tv sat nav units from e-bay
only thing is they are from Honk Kong....has anyone had any bad experiences with e-bay deliveries from there?
SQ_W211
W219 CLS55 AMG
Yup i have first hand experience with them, apart from hidden costs (import duty - £20- 25) its not bad at all, they have everything built in. If possible, i would try to get double din unit as that are better built and at around £250 delivered they are very very cheap. Picture quality will be good and Ipod connection/USB connection works very well too. My brother has it in his car and so does my friend.
Get one from someone who has loads of positive reviews and you should be ok
For your year you can use almost anything,,there is no d2b or most,,loads of options on Ebay. You only have a single DIN slot so a double DIN may not look right
malty123
Nottingham
E350cdi sport 2011
thanks chaps...not quite sure what a single/double DIN is but i'm sure i'll work it out:confused:
A double DIN is a slot twice as deep as the one that you have in the SL
www.ckinsurance.co.uk
