Stick with 19" wheels or bump to 20"?
KennyN
Paisley
Went from 18" to 19" on my CLS , within 5 mins of driving i wished i hadn`t bothered.
Looked great but the crashy ride was woeful on our roads.
20170323_164827_zpsldptijjw by Kenny Niven, on Flickr
Just got myself a small SUV as a daily and aesthetically the 16" wheels are too small for the body but it has really high (65) profile tyres and they suit our roads perfectly , i was contemplating replacing them with 18`s but ,as above, lesson learned.
K
JBell
Torquey
C350 CDi Estate (GAD Edition)
Go for it, still runs a 265/45 R20" tyre so loads of sidewall
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
They are compared to these.... View attachment 50799
Is that what the M1 has been turned into after all those years of 50mph roadworks speed limits.
Back to the OP, I have 20" wheels with 265/45 tyres as standard factory fit on my W166. I have airmatic suspension too. My previous W221 had 19" wheels with airmatic too. Both heavy cars. In your case stick with the 19" would be my advice. As wheel sizes go up, tyre prices go up, and choice of make reduce. Winter tyres also become v expensive and limited in choice to add to the wider debate.
The bling argument about filling the arches goes to the wall once you raise the suspension, too :geek::rolleyes::cool:
Also 1" wheel diameter increase with corresponding tyres gives an overall diameter of wot compared to the 19" you currently have? I would venture 9 parts of diddly squat.
For example my current set up gives an outside diameter of 29.38" (tread width of 265mm x 45% = 119.25 / 25.4 = 4.695 x 2 = 9.39 + 20 = 29.39"). If I had the other available 21" wheels with 265/40 (265 x 40% = 106 / 25.4 = 4.17 x 2 = 8.35 + 21 = 29.35") tyres that gives an OD of 29.35" so in reality they are 'smaller'. By changing the wheel style to a 'fuller' amount of metal as opposed to say 5 spoke, you would give the illusion of bigger wheels if that is the reason for changing a perfectly good set up :geek::rolleyes::cool:
peternutkins
Charmouth Dorset
c220 cdi estate 2001
I don't much like the ride on my C220 with 16" tyres and am actively looking for some 15" wheels. I am used to driving hydropnumatic Citroens.
Peter
Peter
Drop the tyre pressure to the bottom of the recommended (if you haven't done so already)
Peter
You need an ABC equipped car...
ABC is based on the Citroen system....
Abb
Mercedes
We have 21" on our W166 and it's fine. Came with 21" from the factory albeit a different style. Ran 22" at one point but then changed back to 21" for no other reason than another set I was after came up for sale. It does have airmatic though.
On a separate note, the CLS has a conventional spring set up and came with OEM 19"s, which are soon to be replaced with 20"s as was my previous CLS which also had airmatic.
More than happy with the ride :)
Be a dull place if we all liked the same thing. :)
