sidewaze samm
- Jun 12, 2012
- Location
- greater manchester
- '14 X156 GLA 250 4matic
I few weeks ago my engine management light lit up (amber). Car drove fine. EML goes off after a couple of hours.
This scenario has repeated since then, several times. Sometimes the EML is on for a few minutes, sometimes for a couple of days.
Booked in for investigation, but the EML went off before I arrived and I was told that the light needs to be on, as my 2014 car does not remember EML fault codes when the light is off.
But, it's impossible to get a booking at short notice and so far I've cancelled two further bookings because the light was off on each occasion.
Also, this past week the stop/start has failed to 'initialise' (I mean the ECO doesn't light up green showing that it will activate after coming to a stop) even when all obvious parameters for its activation have been met (outside temp, engine temp, current drain, time since last activated, length of drive...). Over some 10 days and 350 miles, the stop/start has probably been in 'initialised' state for about 25 minutes.
There are no issues with either the performance of the car or with it starting. Everything seems fine apart from the above.
Coincidence or connection? Anyone any solutions or suggestions?
