Strange 722.6 Gearbox Question
Stuartph600
Cl600
Ok
What colour should the oil be in a 722.6 transmission , even when dirty
And how should it smell ?
Also should the oil be very thin or quite thick
Clean oil should be cherry red in colour becoming brown to black as it gets old.
It should smell slightly sweet but when old smells burnt. It should be thin, watery almost when hot. If in doubt change it.
Stuartph600
Cl600
It shouldn't smell like gear oil 75w90 stuff or be as thick as it?
Stuartph600
Cl600
i changed the gearbox electrical socket , to see if that might help with my problem
But the oil that came out smelt like gear oil and not very thin
Toast gearbox putting car into limp mode maybe
A STAR session will soon show if that's the case. I may be over your way in the next few days and could bring STAR with me if it helps?
Stuartph600
Cl600
I might take you up on that offer , thats very kind
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
It is a red colour in the can. That will change over time to become darker but should still have a red tint.
It shouldn't have a burnt smell.
It is quite thin.
(apologies -- I delayed typing and saving the response and LostKiwi beat me to it)
John Laidlaw
Wirral
Land Rover Discovery 4
They used to say a slight ‘Cherry’ smell but certainly shouldn’t smell badly or be thick and burnt!
Stuartph600
Cl600
Its thick and just smells wrong to me
Somebody might have added a load of "stop slip" to it in attempt to fix something.
bembo449
gainsborough , lincolnshire
its similar to cooking oil in consistency pal but echoing what the others have said , if your gut tells you its wrong , change it , cheaper in the long run
Stuartph600
Cl600
old oil drained out today , it defiantly smells of gear oil but its not totally gear oil
i've run a magnet through the oil no swarf so far
There is normally a magnet in the sump . You know there is a filter in the sump as well ?
Stuartph600
Cl600
Yes i did know , i don't want to change the filter yet
The sump plug has been chiselled off before !!
Stuartph600
Cl600
  • #18
Yeah its possible but its least of my worries at moment
Stuartph600
Cl600
  • #20
Just the same fault its had for ages , just thought id go in different direction to fix it
