Strange aircon noise W126 SEC
Status
Not open for further replies.
steveb
I have recently bought a 560 SEC, and notice that with the aircon running I get a peculiar noise - about every 10 secs, there is a noise like sucking air through a pipe for about 1.5 secs. Sounds like it is coming from under dash, but not sure. Is this normal & what causes it?
Thanks for help. I am Merc newbie, 'grown up' from Saab turbo so hope to be able to contribute in due course.
Steve
nickh
Hi.
Does your aircon blow cold air at all?
I had the same thing on my w124, the aircon was cool, and sometimes cold for a while. I had some aircon specialists come around and regas the system. Now the noise has gone and the aircon is cold again.
I expect you will be running on the old r12 gas which means you will have to have this taken out, then the compressor cleaned then a substitute r143 gas put back in. I know this as it was all explained to me by the aircon man.
N
steveb
The aircon is functioning - output is quite cool, although I don't know how effective the units should be. The gas is as original R12 - is it a costly job to convert?
Steve
nickh
I can tell you it will most likely be around £100 all in.
you have to pay for the extraction of the old gas, a clean of the compressor, and the new gas, the process will likely take around 1 hour or a bit more.
As I found out if you have the later r134 gas then a top up is around £60-80
steveb
Ta for help - I will try local independant.
Steve
Badger
Milton Keynes
Just out of interest :!:
My dealer quoted £165 to service and re-gas my aircon.
Went down the place down the road that had been recommended and they charged £96 + VAT
:p what is interesting is that the specialist informed me that Merc don't service Air-Con, they get this speacialist to do it!
Status
