rallen
- Aug 29, 2005
- E320 2001 / CLS 320 2007 / SLK 280 2006
Last year I changed front brake disks and pads. Disks were some American make and pads were a good European make. I also renewed the brake fluid and thus managed to put a lot of air in the system which took a while to remove and (look in the other thread) is probably still there.
Because of the thickness of the new disks and new pads, the pistons had to be pushed really far back.
After that we took the car to France, about 700 miles, almost all motorway. No problems with brakes there. We stayed at an altitude of 1200m and the motorway joins in at about 400m or less. During a descent the following days, and at the end of the descent, I noticed a terrible smell and the brakes not working well. On examination it was the brakes being extremely hot. After the brakes cooled down they were OK once more. This more or less happened on every descent (usually in the evenings after skiing). Two weeks later, on the way back home, on the motorway it started to rain heavily. I had to brake somewhat hard and noticed a great judder coming from the braking action, the car was shaking as if the disk had warped or as if the water had caused the pads to slip-bind-slip-bing creating that vibration.
On top of the above I would like to add that we have been at the same place skiing multiple times with the same car under same loads and conditions and that smell coming down the mountain and brakes going soft never ever happened. Neither did the vibration on the motorway, which was one off thank God.
It has been 6 months since and the car has been in rain and motorway and no more vibration. But I have not tried it descenting the mountain.
Would anyone know what it might be causing the heat and perhaps even that vibration?
