strange squeek??
sara786
I have a merc c180 p reg, which has suddenly developed a squeeky noise is the best way to describe it. Also when you push down on either frontside it squeeks , also when turning the steering wheel either left or right when stationary, yep its squeeking.
Can anyone suggest what the problem maybe , by the way it clocked 102.000.
all replies appreciated.
thanks
Sara:confused:
Ellsy Tanners
Mars
Hi Sara
It could be any number of front suspension components, Most likely anti roll bar bushes or lower ball joints.
Needs to be listened to on a ramp/pit to be 100%
Ellsy
thebob34
S 280
Hi all, Just joined the group Maybe you guys can advise me. My S280 makes a pretty loud clunk when you turn to the right and even sometimes left. It has just had a service but the garage says when its up on the ramp it doesnt do it so they can't put their finger on it. Any ideas.
Bob
Xtractorfan
S class
The 220 S class has twin botttom ball joints, the rear joint tends to wear, but tends to set up a chattering vibrating sound on certain road surfaces, sometimes the sound can be mistaken for the suspension air compressor coming in... turn the steering to full lock, car stopped , engine running and gently shake the steering wheel against the stop and you should feel and hear the play..
