Stuck callipers..
Shaunm41
2003 Mercedes CLK 270 Avantgarde
Good evening,
I have a 2003 CLK 270 diesel and I’m having some brake problems..
The front N/S brakes were sticking on and overheating so I decided to replace the front disks and pads as there was also shaking through the steering when braking..
While replacing the disks and pads, the brake callipers wouldn’t return all the way in and I struggled to get them over the new disks..
Now the brakes on both sides are sticking as the callipers won’t fully retract and it’s un drivable.. the wheels didn’t turn freely after the brakes were pressed..
Can the callipers be repaired? Or any other suggestions I could try to get things moving again?
I’ve changed disks and pads before but never had problems like this..
Any advise would be much appreciated
Shaun
It’s the pistons sticking in the callipers. They will need a rebuild / cleaned up / new seals
Shaunm41
Thanks, is that a straightforward job?
robin.large
CLS C63 AMG 2013
Just checking that you slacked off the brake bleed nut to release any stored pressure as you try to push the pistons back into the calipers?
Sent from my ONEPLUS A5010 using Tapatalk
Shaunm41
Ohh that’s a good point...... no I didn’t do that... I’ll give that a shot tomorrow
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Did you use a piston push back tool or leverage ?
Shaunm41
I picked up a push back tool from euro.. had to use quite a bit of force with a ratchet on it and ended up bending the plate that comes with the tool
joderest
ML270 2003
Normally, pushing the pistons back would just increase the level in the master cylinder, and as long as the top is off and it is monitored should be no problem, unless someone has topped it up when pads were worn, it may well then spill out.
HOWEVER
It does sound like you have seized pistons in both sides, which will mean removal of the callipers, you can overhaul them yourself if you have the tools and knowledge, but if the pistons are rusted, which is often the case, may be better to have reconditioned callipers, which would make the job quicker. The seals are available, i rebuilt my rear ones on the W163 last year for this problem, right hand side was sticking causing a brake issue.
I would look on ebay or check a site like Eurocarparts for prices, or if you have a garage near you that would perform the overhaul for you.
Good luck
onefortheroad
uk.
That shouldn't happen. Try cracking the nipple and try again.
Shaunm41
Thanks will give that a try tomorrow and maybe pump and wind it a few times see if it’s free..
Shaunm41
HOWEVER
Good luck
Thanks for your reply, I’m hoping it’s not as serious as that, but will see tomorrow
onefortheroad
uk.
Don't pump too much your piston may pop out :)
Brakes International do really good refub calipers with a part exchange option.
Shaunm41
well atleast it won’t be stuck then
Shaunm41
So I’ve slackened the bleed nipple off and managed to get the pistons all the way in, fitted the new pads and the wheels turned freely.. went out for a drive and they got pretty hot and one produced a little smoke which I believe is normal.. I think I may just sent the callipers away to be refurbished..
Pushing the pistons back in if they’re seized is a bad idea. The rust on the outside of the pistons (what causes the seizing) will likely damage the seals as it’s forced past them.
I’d get them refurbed pronto.
joderest
ML270 2003
It does sound like the pistons are not retracting correctly.
Be aware that the hose connection can be very tight into the calliper, and you cannot use heat to free it off, for reasons that do not need explaining !!!.
I used a freeze spray, which worked very well, you must have a decent tight fitting spanner.
Good Luck
onefortheroad
uk.
Brakes international will sell you 2 calipers and give you money back when they receive your old ones.
ajlsl600
france
Leave one pad in use Tyre lever, gently force piston back, watch level in mcyl does not go up such that b/fluid goes al over the place, many make mistake of topping up as pads wear down. After getting one back fit pad, repeat for other side
If piston does not move freely I have fitted grease nipple and pumped them out for resealing.
