Suck or drain Engine Oil?
John77
E200 Estate 2011, 2009 SLK 200
Probably asked many times. I have searched first, but is there any difference between sucking out the Engine oil or draining from the bottom apart from the time it takes? Also while I am here. Which is the engine oil dipstick tube on a 2009 SLK 200. Left or right as you face towards the back of the car.
mattkh
England
A160 W168 1999 1.6
.......is there any difference between sucking out the Engine oil or draining from the bottom
Things to consider :-
1. Would the last mechanic have overtightened the sump bolt so much that I will struggle to loosen it.
2. Is the sump aluminium, thus easy to crack when I tighten the sump bolt..?
3. Do I have a new washer for the sump bolt..?
4. How will I know that I have sucked all the sludge at the bottom of the sump..?
I always use a manual vacuum pump for my oil changes where I can (V8 M113 has no dipstick, Smart has no dump plug...)
It's a Sealey 6.5 litre pump (so needs draining part way through).
Usual method is:
1. Warm up engine by going for a drive.
2. Start sucking oil out.
3. Go inside and make a coffee.
4. Check pump ready to be drained.
5. Drain 3 litres from pump
6. Go inside band drink coffee and have a biscuit or slice of cake.
7. Go back outside and change filter (prime pump before reassembling).
8. Refill sump.
9. Go inside and have another coffee.
10. Check level and adjust if necessary.
11. Start engine and check for leaks.
12. All good? Go for drive.
EmilysDad
Bury Lancs
ML350
1.....
Your car will have been regularly serviced so there wont be any sludge in the sump anyway ;)
Doug1234
Bedfordshire uk
1997 w210 e300td
Suck oil out as opposed to crawl under car and possibly have to remove a cover to access sump and then the possibility that one corner of vehicle needs jacking up to get your container under to catch the oil !!!.
Manc Rick
Manchester
W213 E220 Premium +, 2017 with OM654.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
So you are saying that pumping is best? I have a manual one.
Manual or Electric really is a matter of personal choice, I prefer Electric as it’s less fuss, ensure the discharge container is big enough to take the contents of your engine, warm the engine up, max temp of oil for the MM pump I posted is 60°C, insert the suction pipe down the dipstick tube, place the pump in a secure location and secure the discharge pipe in the waste oil container, switch on.
Previous experience as either a Downhole Tool or Wireline Engineer in the Oil and Gas drilling Industry or a Gynaecologist! would provide to you a distinct advantage in the manipulation techniques of the suction pipework from the top of the hole in order to pick up the last dregs of old oil from the nooks and crannies of your engine sump! :)
Potential pitfalls?
Not securing the pump and/or discharge pipework effectively and returning from your tea break to find the contents of your sump in a big black puddle under your car somewhere! :)
Gazwould
C250 CDI
Gazwould
C250 CDI
Be kind to yourself and get a manual extractor and receive a triceps pump like Arnold .
DREAMER NO2
W124 2.6E M103 1989
Best to find out the right dipstick tube for your engine oil to start with . Auto box will have a red lock on it thats nor easy to open, so dont use that one the .engine dip stick just pulls up and out . Best to drain old oil out of the engine through the sump drain plug .That way the old oil will bring out the dirt and sludge ,,,thats if there is any. If a oil extractor pump is used, it might miss the particles that are on the bottom of the sump. I drain the old oil out through the sump plug,, because my sump plug as a magnet inside it, that needs cleaning .If you opt out and go for the extractor then do the oil changes more often till you klnow it is a clean engine .
Gazwould
C250 CDI
Guess you haven't heard of dispersants in the additive package that hold impurities in suspension with their lovely little polar heads and hydrocarbon tails .
EmilysDad
Bury Lancs
ML350
..... Auto box will have a red lock on it thats nor easy to open, so dont use that one the . ......
You'd be very lucky to find a dip-stick on an auto box these days of what ever make. The last car I had with a dip-stick on its gearbox was my 92 Senator, the 99 Omega had a fill/level plug on the side even though it was basically the same gear box
John77
Has both tubes. Thank you for all your inputs:)
EmilysDad
Bury Lancs
ML350
not a new car then .... ;)
the dipstick for the autobox will likely be longer with red oil dripping off it, while the engine dipstick will be somewhat shorter with gold coloured oil dripping from it (or black depending on how long it's been in there ;)
John77
  • #17
2009 SLK200. Only ever had one new car. A Renault 18 estate. So that shows how long ago that was. 1978. I have always bought second hand and so far never been disappointed or had any major problems and now I have been retired 10 years, so would never see one again.
EmilysDad
Bury Lancs
ML350
I've never ever had a new car ;) Bought when 3 or 4 years old is the newest I've had ..... I've never been able to afford or willing to pay for the cars I liked when new.
2009 car shouldn't have a dipstick in the gearbox tube. They stopped that in the late 90s.
John77
  • #20
No dipsticks, just tubes with caps.
www.ckinsurance.co.uk
