Sun roof drains 220TE
Casual Traveller
Stourport-on-Severn, Worcestershire, UK
1993 220TE
Greetings,
I am still having a problem with water leak/s on the passenger side of my 220TE. I have been through and cleared all the under bonnet drains (sides and heater).
The leak seems to be running from under the dash and down the side of the gearbox tunnel. I am not loosing coolant.
There are only two more things I can think of doing. One is to replace the wide rubber seal at the bottom of the windscreen as it is loose and will not clip back in place. Has anyone else had this problem?
The other is to check the sun roof drains. I have searched numerous previous threads and much is blamed on sunroof drains.
Please could someone advise on the position and route of the drain tubes. I have looked around the sunroof frame but can't see any drainholes. Is there a drain tube that ends up at the centre of the bulkhead somewhere?
Many thanks, Graham.
www.ckinsurance.co.uk
