There's no detail in the user manual. It looks like I need to remove a plastic casing which goes from one side of the boot to the other with numerous (approx 16) various fasteners. Seems very complicated for a simple bulb replacement.How do I replace the tail lamps on my 2006 SLK200
Are you sure the felt doesn't just pull back at either end of this plastic ?There's no detail in the user manual. It looks like I need to remove a plastic casing which goes from one side of the boot to the other with numerous (approx 16) various fasteners. Seems very complicated for a simple bulb replacement.
As said, nip to Halfords, they charge I think £10 - saves the hassleThere's no detail in the user manual. It looks like I need to remove a plastic casing which goes from one side of the boot to the other with numerous (approx 16) various fasteners. Seems very complicated for a simple bulb replacement.
I thought there would be , well photographed buddyThere is...
Passenger side
Finger in the little hole and pull it back...
Reach up inside and this is what you have...
I like pictures, saves typingI thought there would be , well photographed buddy
I just cut and paste....I like pictures, saves typing
Wallpaper is out of fashionI just cut and paste....
