Telephone Microphone. Where is it supposed to be on an 2003 S Class?
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Hello all....
I have a bit of a problem with the in car telephone system. I have recently fitted the full kit from a 2002 S Class into my facelift 2003 car.
I installed the D2B fibre ring, the control box under the seat and joined in all of the necessary cables for power etc. that were on the loom.
There was however, no socket or wires for a microphone and now that I have installed everything into the car; bought a nokia 6210 and the whole thing is working (on the screen, and on the dash) I can ring people (sound through speakers etc) but no one can hear me!!
How do I find where the microphone is supposed to go when there was no where for it to plug in!!??
Help please
Thank you
Barry
barry jones
barry jones
Warrington
  • #2
anyone tell me the answer please?
whitenemesis
CLS55 AMG '05
Usually the mics are in the RVM. Check the underside, there should be 4 small grills
Yes they are installed as above,,I cant see a mike listed on the Ruskie site,, but I will look on the retro fit in the morning
whitenemesis
CLS55 AMG '05
I don't think there is a MB retro-fit for mics...
They are part of the RVM, so possibly just fit a suitable RVM?
Retro-fits of MB phone kits and Linguatronic use stand alone misc attached to the headlining and A pillar
barry jones
barry jones
Warrington
Yes I've seen the retro fit kits but I can't find anywhere on the module (under back seat with fibre connection) to plug a mic into. Also nothing on the wiring or on the cradle etc.
I will check the RVM tomorrow because I have fitted a full harnes and fibre from a 2002 car into my 2003 facelift car. There was some prewiring in the 2003 car which was taped up behind the radio. One was a small 2 pin plug with greeny wires and the other was the antenna cable to the rear roof antenna. Would it be possible to scrap what I have fitted and stick something to the pre-wiring that was already in?
Either way is fine but either way I need a microphone to speak! The sound from the kit is good as is the signal strength; unfortunately no one can hear me speaking!
Thanks again for the responses
baz
PS, Malcolm, any joy with the tv wiring from 2002 tuner to 2003 widescreen DX nav head unit!?
barry jones
barry jones
Warrington
Just been out and taken out the overhead console. Behind there is a small black cable( 2 core and very similar in size to a microphone cable) there is a small 2 way black plug on the end. The plug was wrapped in foam. Could this be the mic cable and do Merc do a plug in mic for the roof console?
The mike is not on the car but they are pre wired,,you just need the mike. I have a paper on this if you care to PM me with your Email address
Details sent,,I have forgotten what I was looking for on the TV part,can you refresh me please
barry jones
barry jones
Warrington
Got them thanks.... part ordered!!
The TV stuff I needed was a wiring diagram to connect the TV tuner from a 2002 S Class to my 2003 Facelift S Class with the DX widescreen head unit.
You said you may have a wiring diagram showing which pin on the tuner would go to which pin on the C21 connector at the head unit
Thanks again Malcolm
Barry
barry jones
barry jones
Warrington
I tried the cable wrapped in foam and tried pushing the ends of the cable from a nokia microphone I had in the garage. Nothing happened and the person on the other end couldn't hear me. It may not be quite so easy as just connecting the mic up after all.
Maybe back to the cables behind the radio. I have an antenna cable and a green pair of cables which terminate into a black plug which may plug into a control box or something? Anyone help? Would it be worth me putting a picture up?
I really do need to get the phone working in this car and I don't want to bolt on a parrott system when the car has its own built in!
Baz
If the mike is an electoet there are 3 wires and it needs a voltage to drive it
Tel: 020 8863 9233
