Jay Kilby
Hi i have a 1981 500sl which i have collected on the way home we started having fun with the engine temp. it started to get really high then if i moved the heater to hot the engine temp went down.
now i think it is a faulty thermostat not opening when it should, because after a while the temp dropped below 80deg with the internal heater on cold then for no reason the engine temp went up again??
any tips would be good
thank you
thank you
