Mikesmerc
- Jul 3, 2003
- Location
- Co.Cork IRL
- 2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
I want to test the injectors to see if they are leaking, dribbling or fine spraying. Having trouble getting someone to check em in my area. Would it be possible to remove a bank of injectors complete with the fuel header, extend the fuel supply hose from the regulator so as they are out of reach of the engine bay. Hook up a remote 12v battery to each injector via a remote switch. Turn on the ignition and pressurise the system, flick th switch and see if the connected injector sprays correctly. You should also see if any are leaking.
Is all of the above rubbish or should it work?
Thanks for any replys.
Rgds
mike
Rgds
mike
