duncanh
- Mar 2, 2007
- Location
- Wiltshire
- BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
I am beginning to think that my w203 220cdi estate is finally approaching the end of its useful life.
Having covered 343k miles, it is not surprising.
Over the last couple of months the rear suspension rattles (and squeaks and bangs) have got much worse, the a/c has packed up (may only need gas), rear screen washer tube that goes through the rear wiper motor has sheared and hardly any heat is coming out of the heater.
I could live with these things, until I had some time off over Christmas to look at them. However this weekend it found a couple of new tricks to play.
I turned the key, all normal lights etc on the dash worked, but the starter failed to engage. I did it again, it worked straight away. Later it did it again, this time I had to leave it for ten minutes before it would start. Coming home along the M4 I realised that it had lost most of its power, it was obviously in safe mode. I wonder if the 2 things are related, probably not.
This morning it started straight away, I travelled to work (in safe mode), switched it off, tried to switch it on again and it was dead again.
It might be the started motor, maybe the EIS, maybe a relay, maybe a loose connection, a bad earth, a SAM module. Who knows, but I wont get a chance to have a good look until the weekend.
I am hoping it will start tonight and get me home. If not, the breakdown service will get it home.
I will then park it on the drive and use the wife's car for the rest of the week. Given the multitude of problems and the mileage, I am wondering whether to take it straight to the scrapyard. It would be too difficult to sell in its current state, although it has 2 new tyres (2 weeks ago) and 6 months MOT remaining.
That then raises the question of what to get next. I got the W203 new 12.5 years ago., but will not be getting another new car. I am looking for something equivalent between £10 - 20K. I have seen the bad publicity surrounding the newer Mercedes 4-cyl diesels (same with BMW) and their timing chains, but don't need a 6-cyl and the poorer fuel consumption.
Just how risky are the 651 engines?
It's a bad time of year to be without a car.
