YTerminal 87 relay is in the front sam. But this is the output to the relay and not a relay fault. It is probably just that the relay was slow to switch or be switched by the cdi. If you are not having problem starting then I would not worry too much.
yes relay 87 (KI) powers ecm I am haven issue with that relay not switching ,You really cannot use circuit 87, 87 refers to every ECU and relay, 87 is the live feed on all.
Did you find the solution. AM having same problems with C270 w203.. When trying to start turn the key to start.. The starter will turn the engine for about 3 sec then the starter bendix will come off from the ring gear the starter will keep running itself.. I changed 2 starters it's doing same... The fault P1610 is coming out. I changed relay 87 doing the same.. But is you feed the power to starter solonoid it is cranking very normal but doesn't start the engine only cranking.. Any1 with help pleasePlease I am having similar issue, car a 2008 E350 won't crank and its showing some error about circuit 87. Please i need urgent help on this, because I am tired.
This looks to be true... Am failing to figure out were is the power dropping from my car 203 c270 am having similar problemCDI terminal 87 relay is the relay that the CDI energises once the DAS has read and authorised the key in the ignition switch. This then in turn powers up the CDI control unit.
So in actual fact the CDI sends its own signal out ( terminal 87 request ) to enable power to itself from the front SAM.
Hello and welcomeHey Guys,
Another w204 c200 2012 trouble......water seeped into the footwell through clogged drains....now car is going crazy, it reaches ignition but doesn't crack with few error messages. Once very peculiar finding is clicking sound in Relay N (circuit 87) in front SAM. When this clicking goes away all the error disappear and car behaves normal. But when it starts anti theft protection warning, no gear selector indication, and few other things. Any guidance on what to look for.....appreciate the help of experts here.
