I need to locate my reverse light fuse and do not have a fuse layout for the fuse box in the front of the engine, c180 1997 r reg. the reverse lights just stopped working.
No it's not the correct one many thanks for going to the trouble, I have checked the bulbs and every fuse in the front engine compartment, there does appear to be a couple missing though.
Are you aware there is a fuse box in boot, behind battery? Sorry cant help any further, someone must have the info you require, hopefully the will see your post.
