Thermostat bypass pipe e270 CDI and c270 CDI
Sponcom
Cirencester
C class/2002/270CDI
Can anyone tell me the reason an E270 CDI thermostat does not have a bypass pipe but a C270 CDI does?
Many thanks
Paul
mersum1es
Finland
rpe2
Silchester
A change in engine design.
The earlier 611/2/3 engines have one, the later (electronic turbo/ egr) 646/7/8 engines do not.
Hence the need to order the correct stat.
mersum1es
Finland
Thanks, didn't know that W211 engines,and only W211, were all OM647s...(though OP didn't said which model E, W210 has OM612).
Sponcom
Cirencester
C class/2002/270CDI
Thanks for the replies.
I asked the question as a replacement bottom end from an E class 270 CDI was fitted to a C class 270 CDI 2002 (612 engine). However during assembly it was realised that the E class bottom end had no channel for the bypass pipe. The engine was fitted with the appropriate thermostat with no bypass and appears to run fine.
I was just curious if there was a particular reason for the water channel fed by the bypass pipe.
