Thermostatic heater W202 C280 94
Status
Not open for further replies.
Myros
R107, S211, R170, C219
Not that it's too much of a problem in this weather, but I find I can't get any cool air out of the ventilation system. Except for the two centre vents, which I know are separate, all the others blow hot or hotter, despite the controls being set to as cold as they will go. I don't have aircon, just the standard thermostatic heater system. Any clues/hints/tips or sympathy much appreciated.
190
Banned
Scotland
First thing to change is the pollen filter if it is clogged up it will restrict the air flow you will not get the cold air coming through and the same goes for the warm air it wont be as warm.
dieselman
A diesel
Probably the heater valve has gone. this then leaks hot water through all the time.
Myros
Myros
hot under the collar
Thanks fellas, I'll try both fixes in ascending order of muckiness, and let you know how I get on.
Myros
Myros
done and dusted
Thanks for the help fellas. I did the pollen filter a while back, no change except the hot air coming through must have been cleaner. Had the duo-valve done the other day, heater back to normal. Expensive little bit of kit, isn't it? £115 including my MBOA discount, and that's without the labour and sundries.
Merry Christmas to you both.
Status
