Three hours later and this still isn't unplugged.. How do I do it?
dpmstevens
A180CDI 2006
I'm taking the seats out of an W169 A180, and I cannot get this plug undone. It's under the seat. I have managed to remove part of the outer casing but the male part will not come loose. It's taken three hours to get this far... I'm tackling the A-class flooded interior problem which has messed up the COMAND system and possibly the ESP, so it would be good to remove the carpets and get it all dried out first.
Does anyone know how to release it?
Cheers
Dan
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Do you not have to disconnect the battery , red is danger ????
mattkh
England
A160 W168 1999 1.6
Try pushing the plug into the socket before pressing the tabs and pulling it off.
D
dpmstevens
A180CDI 2006
Thanks everybody.
I might be missing something here, but I watched that video of the guy removing the seat and he seems to shove a screwdriver down one side and then pulls it apart, which I have tried.
Help me out - where's the tab and which bit do I lift?
rich.g.williams
Cardiff, South Wales
C200 Kompressor Coupe 2003
Try having a good look at this site :-
Seat mat emulator Mercedes - installation
Don't use screwdrivers, cut a piece of old plastic Card (Credit/Debit?Loyalty) if a shim is needed.
Some connectors its a matter of releasing the tab that locks them together then gently prizing the male and female connectors apart.
Looks like there are things (more than one) to unhook
D
dpmstevens
A180CDI 2006
Thanks for the link - unfortunately it only shows how to undo the yellow occupancy sensor connector, not this one. The guy in the only video that shows this thing being disconnected appears to lift a locking tab from where the seat belt buckle wiring plugs in, but there just isn't anything to lift.
Botus
S500/2010/500
in first pic what the white bit - is that supposed to come out before you play ?
ajlsl600
france
Be sure disconnect batt to avoid drama, every time makers, all fit another harness or extn to some git dreams up a new way to aggrivate owners..
rich.g.williams
Maybe post say four photos of the connector from different angles, someone might recognise it.
D
dpmstevens
A180CDI 2006
I've given up. Taken it to two garages and neither could fathom it. In the end I cut the carpet and pulled the seat forward to give enough clearance.
