nuppy
Ok guys this is the last problem with my E200 (1998) after buying the car a was unhappy with the feel of the throttle pedal I removed the cover next to the throttle body, which uncovered a very complecated linkage most likely due to the fact the car is a auto. What i did notice was a lot of movement was required to take up slack in the linkage before the throttle was opened the slack was mainly due to the shape of a ark in the linkage it seamed to be worn. Again due to my lack of experance with mercs i'm unsure if this is normal or not. So i adjusted the cable to remove the slack the car now drives better but sometimes makes strange gear changes. I have pined out the ECU and the throttle switch is working correctly.. But sometimes when driving along I think it's never going to change up.
Thanks for any help Neil.
