Throttle pedal
didi
fife
c220d,clk200
My clk 270cdi has faulty throttle
I have clk 320 petrol pedal Question can I use petrol one on clk270 pedals are exactly same difference is part number
Thanks for helps
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
Try it, if it doesn't work swap your old one back. ;)
mioba
Nottingham and Köln
What do you mean faulty pedal. Whats the issue.
I have never seen a faulty pedal.
D
didi
fife
c220d,clk200
Diagnostic fault was faulty throttle pedal
Car does not accelerate some times does but cuts off
First miles ok then fails Also kick down works ok and dies too Diagnostic fault was pedal ?
D
didi
fife
c220d,clk200
I’m getting pedal tomorrow I will try it’s easy job anyway Also if works pedal is only 15 pounds
mersum1es
Finland
well you could check are they 'replaced by' part numbers... it shouldn't be engine related anyway. Same pedal in few chassis.
I have, mine W211 had broken one. Drove fine but occasional EML. SDS gave a fault code. I also fixed it by 2nd hand part.
Mark A
Aberdeen
58 ML-320CDI.
I hate to disagree, but I have had 2 faulty throttle pedals on my W164 420 CDI with. +/- 5yr gap between them.
In both cases it manifested as a high idle speed +-/1200rpm. If I put my foot under the pedal and lift slightly the idle settles back down to a normal 700rpm. Nothing to service in the pedal, either put up with it or buy a new one.
