ERRR, Would help if we knew what car it is?
Crank Damper?, what is that? bottom crank pulley has a rubber mounted pulley, do you mean that?
Thrust Arm Bushes?, I would imagine are on the front suspension, probably inner lower arm bushes, can you confirm which ones?
Both those terms are not normally associated with MB, as far as I,m aware.
Could you describe to me exactly where these parts are? Unless anybody else knows what parts Jaikothari means, from these terms.
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
