Thud on W123 200 1982
agence
Hello,
I'm considering buying a MB 123 series 200, 1982 [see the other thread I've posted in] and it looks all good apart from a bit of a thud noise back right which the owner says is just the need of a new shock absorber which costs about £25 and is easy to fit...
I have friends who can help me with car issues but am not near home at the moment so just asking people here if this is likely and is it actually easy to fix?
Thanks for your help!
bonez
If its only a shock absorber thats little cash and easy to fit.......why has'nt the owner replaced it....maybe a question to ask him.
I am not aware of shock obsorbers making a noise. pushing the rear of the car down,and releasing, the car should not bounce.
Malcolm
A
agence
Thank you for those comments, bonez and television. I'm seeing the car again tonight so I'll probe further.
tom7035
Malcolm
It's not the shock absorber which makes the noise. It's the lack of damping of the suspension which 'crashes' over the potholes and bumps.
Thanks TOM, easy to forget, when they are that bad.
malcolm
A
agence
is that bad :confused: :???:
Nothing that new shocks wont cure. Good shocks transform the ride. cheap and easy to change.
Malcolm
A
agence
Excellent, thanks again Malcolm - I'll be buying this car on the weekend and get it sorted soon after!
TimN
Hertfordshire
If its that bad then chack that the rear springs have not broken and also check that the rubber stop in the wheel arch has not come apart. If it is constantly being hit the rubber will have seperated from the base plate. You will probably see the base plate still attached to the chassis rail. Not a dificult job to replace. A broken coil spring is a little more difficult to replace.
