Timing belt
O
oilyfingers
Hi, mother-in-law has just had her A class serviced & new r pads by local garage as all i used to do was reset service indicator & change oil/filters. He has recommended timing belt change as he claims its got cracks in it. I,ve changed belts on peugeots, vauxhalls & landrover but not on mercs. How difficult is it as i think she,s going to approach me to do it? I originally thought these were chain?
whitenemesis
CLS55 AMG '05
Timing is by chain but there is a poly 'V' belt that drives the ancillaries.
O
oilyfingers
So i was right then. How hard is the belt to change as i know some motors are awkward to re-tension belt?
whitenemesis
CLS55 AMG '05
You need to release the auto-tensioner but I'm not clued up on the details. I'm sure someone will be along to fill in the gaps! ;)
Releasing the tensioner is easy. Wack a socket on it, turn anti clockwise, remove old belt, put new belt its place then release the bolt.
Its spring loaded, obvious when you do it.
O
oilyfingers
Thanks guys, i,ll look into getting a belt for this then.
Access is the problem here - it can only be done from beneath, and is a bit of a pig even then.
scotty2hotty81
Good luck with the socket, DIY these are a pain.
Oh crap, didnt see it was an A class!
baguss
New Registration
Hamilton, Canada
E300 Turbo Diesel/1999/W124
I want to buy 1999 300E Turbo Diesel with 265k miles on it.
The dealer says there are a few types of warranty plan. i.e. engine, tranny, electrical, etc. Based on this model and mileage, what kind of warranty is recommended?
At what mileage should I change the timing belt/chain for this model?
Thanks,
S.Speed
Lancashire
Older Citroen Now :-(
You will get far more attention to your question if you start a new post.
If you dont then a lot of people read the original post title and think "Ah Ive already read that one"..
