tiptronic not working
delboy777
KEITH, MORAYSHIRE
2001 W203, 220CDI Elegance Full Leather/Sat Nav
Help !!! car wouldnt start battery flat, followed instructions in manual and jump started it. took it for short run 1 mile or so and discovered it wont change up or down gears everything else seems ok. Is it just a duff battery? or what do you think. car is w203 cdi 2001..........thanks..Derek
Ps car would not start when i came back, but only did 1 mile with lights on so bat would not have charged
SAM will answer this one,
Cole@MBS
www.mbssouthampton.co.uk
First, why was it flat, two, dont keep jump staring it! the chances are the gearbox has a fault code of the voltage to the supply vavle is to low, a good charge up should clear the fault!!
delboy777
delboy777
KEITH, MORAYSHIRE
Ok no problem i think the battery is knackered, i only got the car on saturday so dont know when it last was changed. Any special precautions when changing battery ??
delboy777
delboy777
KEITH, MORAYSHIRE
thanks guys any recommendations on the brand of battery?
Anything but Varta!!!
SAM is allergic to them:D:D:D:D
Bosch,Exide,Banner, Lucas do not get a halfords or house brand.
Your local motor factors that supply the trade can do you a good deal (yellow pages) Costco and Mackro keep Exide
delboy777
delboy777
KEITH, MORAYSHIRE
Thank you guys, your help is much appreciated, just hope that cures the gearchange problem
delboy777
delboy777
KEITH, MORAYSHIRE
Fitted new Bosch battery and all is well, everything appears to be working ok. Pity it started to **** it down midway through the change. It appears the batt that came out is the original unless someone bought a MB one at some point in the past. original was rated at 100ah but the new one 95ah so not much difference it was the biggest i could get. Thanks guys for the advice............Derek
Cole@MBS
No probs, that will be as good as the old one!!
www.ckinsurance.co.uk
