Top gear
TheBoz
E250 2014
When/what speed should the car go into top 7th gear? e250d 2014
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Depending on temperatures, usually between 60 and 70 mph.
T
TheBoz
E250 2014
So if I were driving at our regular speed of around 60, would it be ok if car was only in 6th? Surly it would be more economical if in top gear.
Sorry if stupid question, new to the car and forum
Hello and welcome
Depends upon a few variables - temperature being one of them (it will hold lower gears to get to temp - what is your engine temp?)
Driving mode - S will hold gears C will change up earlier
Throttle position, steady or coasting likely to be in top
Uphill, downhill or level travel - uphill can stay in lower gear
You can knock the flappy paddles (if you have them) to get into top earlier. Alternatively you can tap the gear-lever to the right to get it up the box.
ajlsl600
france
I often tap the downshift to keep rpm up a bit . Today's traffic situation means its often doing no rpm in top better to loose a few mpg than labour motor. In my view and keep flow thru muffler up. My theory anyway.
T
TheBoz
E250 2014
Thanks, up to now I've only been out on the test drive.
However I noticed that it was only in 6 gear and never got to 7.
I Don't pick car up until Thursday as getting PDI inspection at main dealers.
I'm new to car so expect I will have to learn about how the gears work.
What does it show in the display ?
T
TheBoz
E250 2014
6 and E in green
T
TheBoz
E250 2014
I will post more details after I drive it back from Leeds on Thursday, will be on motorway for most of the way.
onefortheroad
uk.
Taking your foot off the ' gas ' pedal a little can make it drop into the next gear.
T
TheBoz
E250 2014
Thank you all for the help, collection on Thursday, will update you then, David
rorywquin
North Yorkshire
An old B-Class.
Just drive it! Don’t overthink it.
s5tuart
2003 R230 SL350
I used to regularly use the paddle to knock mine into 9th when I was gently cruising. It seemed happy to stay there unless I added more pressure to the throttle or started up an incline.
Same with my W213, it would stay in 9th at 68 in manual mode but didn’t always change up in auto
onefortheroad
uk.
Some days I use cruise control at 60 mph . I notice it's gone into 9th by itself. Yet other days it's in 8th and I'm doing the driving. Gearbox and engine temperatures definitely have an effect .
My SL will stay in 9th (on a flat road) at about 40 no problems.
V6 3.0 vs IL4 2.0 in cars that weigh similar (SL is 15Kg heavier...:oops: but probably more aerodynamic :)) so more likely to hold top
T
TheBoz
E250 2014
  • #19
Thank you for all the replies, I decided not to buy that particular car, I thought it had a vibrating when accelerating.
I am not disappointed however as I have now bought a E300 instead.
Looking forward to picking it up Friday.
Will post details in correct forum thread then.
onefortheroad
uk.
Petrol is the way forward. Tbh.
