Top up or down whilst in garage?
BPD07
w208 CLK ragtop, r230 SL350
I’ve a CLK (a208) tucked up in the garage. She’s on a trickle charge, but I’m just having too much fun with a new to me SL350 (r230) the moment to take the CLK out. It’s pretty tight in the garage so she’s parked top down so I can get in or out.
For the next month or so - what would be the best way to leave the top - up or down?
Top up so it stays stretched and the folds don't go hard and crack
I push my SLK in and out of my garage - drivers window left down so I can put the key in - I then use a broom to press the brake pedal so I can put the gear lever into neutral :p
Frontstep
T210 320cdi
You could teach that smaller person what to do !
mioba
Nottingham and Köln
Top up with window slightly open to keep the air circulating. Make sure its clean inside, you dont want mice coming in.
Flyinspanner
Ruislip
Parked top down to save space? - Surely it would only make about 100mm difference max?
As above hood up to stop wrinkles
It’s easier to get in and out without the top up ;)
sausage
SL
Up. If only just because of critters.
Have you seen the size of a Cardinal spider? They are about 1cm smaller than the Australian Huntsman. I had a Cardinal spider in my flat in Reading. I do not want one in my car ;)
www.ckinsurance.co.uk
