Torque Converter Drain During Transmission oil change ?
mrix
Year 2013 W204 Model C350
Hello all, I am planning a Transmission filter and oil change on my Mercedes W204 C350 2013, while looking at some videos I noticed some people also drain the torque convertor ? how important is this ? and why, I say why because the oil seems to be supplied by the same oil from the transmission sump ?
Thanks for any thoughts and feedback.
The torque converter holds ~half of the ATF so it really should be changed as well to give a full change. It doesn't drain out when you take the transmission sump off.
Quite a few threads on it here, please have a search
M
mrix
Hello and thanks, obviously if it does not drain out it will contaminate the New oil when added so it does seem very important to drain it.
EmilysDad
Bury Lancs
ML350
But bear in mind that not every torque converter actually has a drain plug so changing around half the fluid is the best you'll get.
Chrishazle
Nr Ashford, Kent
With a 204 it should be relativly easy to do box and TC together - had mine done a couple of years ago. However, bear in mind refilling is not simply add the required amount of oil, it has to be brought up to temperature to get the level right, and I believe too much can cause electroplate problems, so check that whoever you get to do the job knows the required procedure and has the relevant equipment! Add your approx location to your profile, there may be a known good indie close to you that someone on here can recommend.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Changing at the manufacturers' intervals I would drain the TC and also flush through the heat exchanger which contains around a litre of oil which doesn't drain out of the sump either, partial changes are a personal choice option.
M
mrix
Hello it is a job I will be attempting myself, I have seen so many different YouTube videos it is a very doable job for the DIYer
I have already hunted down the parts and have looked very closely at the procedures, Its actually been a lot of fun replacing parts myself, almost become a hobby ha ha, thanks for the feedback much appreciated.
V6Matty
Newark, Nottinghamshire
Just noticed this is the 350 engine so it will be a 7g box, meaning it’s a full from the bottom only job,
Tony Dyson
God's Country
Unless you flush it, as in this video...
On a related note, do any owners of a manually operated Pela/Sealey/Other Vacuum oil extractor pump know if any of their models have the facility or can be configured to pump FROM the reservoir and not into it?
EmilysDad
Bury Lancs
ML350
I'd very much doubt it but I know of others that have used garden sprayers to pump ATF into a gearbox.
Tony Dyson
God's Country
Yes I can see that, I plan on using my MM Electric pump when the time comes around again, if I'm still alive that is with the current mileage I'm doing lately! :)
robin.large
CLS C63 AMG 2013
The Torque Converter doesn't drain through the sump.
It holds half the ATF.
So you have 2 choices. You can leave it be and accept you will improve the oil in there, or you can drain everything.
You do that by loosening the oil cooler return line at the gearbox until all done.
You can't use a pump to extract the oil.
You need to be careful filling as you will have to fill in stages.
Fill. Fit drain plug, run engine. Repeat.
You need a pressurised bottle to fill through the drain though.
It's messy.....
Sent from my KB2000 using Tapatalk
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
I have the professional model pump, but I have a jury-rigged one as well. I used an clean (very) empty 5 ltr oil container. I inserted a valve from a tube, and a section of the right sized plastic piping with a piece of copper pipe inserted in the cap of the container feeding the trans pipe. A foot pump pressurised the container, and BINGO...problem solved.
