fwd
- Dec 19, 2004
- Location
- UK
- C270 CDI Estate - Smart ForTwo
Hi All... I need to replace the combination switch on my '96 C220 due to the intermittent wiper function being 'intermittent'!! I slaved in a replacement switch into the connector below the steering column and the fault is cured...
I am unable to establish the size of the TORX screws which hold the airbag/horn assy onto the steering column boss... (all the ones I have are the standard short size, and as thus too short to reach into the recess)... can anyone help please ? TA...
Also, What would cause the dipped beam to remain on with high beam selected ? I suspected the combination switch, but when I tried the replacement combo switch (as above) the fault is still the same... stuck relay ?
Thanks again for you help guys...
