Hi, does anyone tow with the 220 Sb estate amg line? I’m after a tow bar to tow a caravan
S Steve Dru New Member Joined Feb 9, 2020 Messages 3 Reaction score 1 Your Mercedes SB estate amg line 2016 Feb 9, 2020 #1 Hi, does anyone tow with the 220 Sb estate amg line? I’m after a tow bar to tow a caravan
LostKiwi Senior Member Joined Aug 25, 2006 Messages 31,356 Reaction score 21,619 Location Midlands / Charente-Maritime Your Mercedes '93 500SL-32, '01 W210 Estate E240 (RIP), 02 R230 SL500, 04 Smart Roadster Coupe, 11 R350CDi Feb 9, 2020 #2 Is it rated for towing? Several AMG models aren't.
OP S Steve Dru New Member Joined Feb 9, 2020 Messages 3 Reaction score 1 Your Mercedes SB estate amg line 2016 Feb 9, 2020 Thread Starter Thread starter #3 LostKiwi said: Is it rated for towing? Several AMG models aren't. Click to expand... Yes it’s just the amg line, I know the amgs you can’t tow
John Laidlaw Senior Member Joined Nov 15, 2013 Messages 26,373 Reaction score 9,163 Location Wirral Your Mercedes Land Rover Discovery 4 Feb 9, 2020 #4 Even some AMG lines due to the rear splitters etc are a problem with tow bars
Blobcat Moderator Joined Feb 8, 2006 Messages 39,028 Reaction score 27,855 Location Grange Moor Your Mercedes R171 SLK280, Smart R451, Land Rover 110 County SW, 997 C2S, R1250 GSA TE 40th, CBR600FP Feb 9, 2020 Moderator #5 Check your vin plate, if it has the numbers you can tow.
OP S Steve Dru New Member Joined Feb 9, 2020 Messages 3 Reaction score 1 Your Mercedes SB estate amg line 2016 Feb 9, 2020 Thread Starter Thread starter #6 Blobcat said: Check your vin plate, if it has the numbers you can tow. Click to expand...
Tony Dyson Senior Member Joined Aug 26, 2018 Messages 4,038 Reaction score 2,585 Location God's Country Your Mercedes 2014 C 220 CDI W204 OM 651 Feb 9, 2020 #7 GTW 4,570 Kg Minus GVW 2,370 Kg Leaves 2,200 Kg max permissible trailer weight. 1 and 2 are Front and rear max permissible axle weights.
