Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI
For motor insurance issues, the broker tells me that everything is ok,once I have the correct driving license, and keep within the specified weight limits. I used a bypass last time, so no programming needed. But I think that if you are using a dedicated MB plug and play set up then you should be ok, once it has been activated into the canbus as it's designed to handle it. The trans cooling system is a problem though as you point out. But in my case, the actual towing will be light, and on level roads.One if the reasons I have not been down this road is the possible. unintended side effects of any such programming. And arguments over any liability. Of the same if I do go down the tow anything big road,I will be fitting my own discreet trans oil temp guage so I can see the before after effects of towing any real weight should it become apparent that there is going to be an issue ii will get something mire capable.
