cataloyking
- Jan 30, 2010
- Location
- n e scotland
- glc amg 4matic
do i need to code my car when fitting a towbar my car is anew glc premium thanks
Yesdo i need to code my car when fitting a towbar my car is anew glc premium thanks
Depends! Coding takes care of the parking sensors and stop-start, if fitted. It also optimises gear changes for caravan towing. If you are only towing a small trailer or even fitting a bike rack, you can make a choice of coding or not. MB will charge upwards of £100; a towbar specialist somewhat less.do i need to code my car when fitting a towbar my car is anew glc premium thanks
I would suggest you've been misinformed, the posts at 2 and 3 are nearer the mark! and if you propose to do any serious touring while towing, you may even need the cooling upgraded for your ATF!thanks for the reply just found out the car only needs coded if a mercedes bar with electric motors is fitted and controlled from the cabin
Just for the record....I would suggest you've been misinformed, the posts at 2 and 3 are nearer the mark! and if you propose to do any serious touring while towing, you may even need the cooling upgraded for your ATF!
