Towing with an auto box - Do I need a transmission cooler?
Status
Not open for further replies.
SJMaxson
Grimsby, North East Lincolnshire
www.maxson.org.uk
I'm considering towing a caravan with my 1994 E220 auto estate (although not until next year, at the earliest).
Any suggestions about this?
I've heard that when towing with an auto box, you need to fit an additional cooling mechanism to the transmission?  But I've also heard that this is uneccessary with a W124 because of the self-levelling rear suspension.
Any advice from anyone more experienced in these matters than I am?
dave elcome
Maidstone kent
You are leaving yourself wide open to flack by admitting to being a caravaner on this forum, but at least i've now got an ally to share some of the flack!!
The answer to your question is most certainly YES, the cooler you can run you auto box, then the longer it will last. In my humble opinion the best cooler kits are supplied by Kenlowe, http://www.kenlowe.co.uk/ and there technical assistance is second to none.
As for the point re the self levelling suspension, this has no bearing on the decision about fitting a transmission cooler, so dissregard that bit of info.
fuzzer
Scotland
W202
Ding , Ding ,  ... unclean , unclean ...
fuzzer
Scotland
W202
Im only joking ... :p
dave elcome
Maidstone kent
Told you so, just wait until Mr Gayle picks it up!!
Andy
West Midlands
www.mercedesservicing.com
Hi all,
I will endevour to keep my personal feelings about caravaners out of this.
I would agree with Dave E with regard to any assistance to keeping the box cool under this sort of load will be of assistance. But is it necessary I am not so sure. Over the years I don't know of any customer who has fitted a auxillary oil cooler for the gearbox, when towing their caravan. Merc boxes are very strong. They have an oil cooler as the gearbox oil passes through the engine radiator. And knowing how MB tend to go OTT with their specs. I sure that that the normal cooling will be adequate. So long as the oil is at normal level and good condition. IE hasn't done more than 36k.
Hope this helps.
Regards
Andy @ www.mercedesservicing.com
Matt Crooke
Essex UK
Dave/Andy/anyone else!
Caravans again im afraid, the inlaws have one, and they have said we can use it when we want. But we wont always be able to use my father in laws car to tow it. Would it be motoring suicide to try to tow using my 190 with 151k on the clock now. It has never towed before, and ive got a feeling that starting to tow on such high mileage would finish the old girl off. Am i being over cautious here or what?
Russel Weston
Reigate
My Old 230E had a tow bar fitted from day one and was bought specifically to tow. Personally I would not like to tow with anything less that 6 cylinders but hey this 230 did okay. The caravan was 18" and built in 1980 so quite heavy. No oil cooler was fitted as Benz SA advised that it was not necessary. The car has now done 266k km and the box is still fine. No rebuild, I dont even think it has had any attention at all.
Matt Crooke
Essex UK
Russell
I have to agree on the engine size, i have towed several times (not just caravans by the way chaps!) and a 4 cylinder always seems to struggle. My 2.8 granny was excellent at towing anything. trouble is the petrol gauge went down as fast as the speedo went up!
Russel Weston
Reigate
Living in Africa, with vast distances to travel I got hold of a Crysler Valiant, 1976 3.7l straight 6. It was a light truck( Ford P100 type thing)it was a beauty to tow with, but thirsty as well, so I put two Merc 80l tanks in behind the seats, added a common feed to the existing 90l tank giving a range of about 1500 miles. This could be done towing as the engine was hardly working at all.
Stewart Smith
Hartlepool
Hate to go over old ground Andy - but did we ever decide what oil to put in them dodgy early auto 5 speeders? - I'd like to do mine ASAP myself.
( Update - did steering idler bush last night - nothing wrong with old one - blooming rip off Merc dealers. Glad I didn't pay £50 labour for it)
Andy
West Midlands
Hi Stewart.
If we are talking about the early hydraulic box which should be in your vehicle. Then Dextron II automatic transmission oil is the correct one. There are many different manufacturers. The electric boxes no diffinitive answer as yet. So I stick with the MB stuff.
Did you check the steering idler for lift as well as side to side play. Its unlikely that even the stealership would report something that there is no problem whatsoever. Labour charges are a different issue!!!!!!!!!!
Regards
Andy @ www.mercedeservicing.com
Stewart Smith
Hartlepool
Nope - didn't check - but put the new one on in any case - at £15 its virtually a service item I guess.  I think mine is the electronic 5 speeder. I could be wrong - I didn't know there were any 5 speed hydraulic boxes. I definiteky wany to change the oil in it though - anyone else got a spec for the oil in a 5 speed auto box?
fuzzer
Scotland
W202
Whats the official line  .. what does w/s stand for ?
Winter and standard
Winter and sport
Matt Crooke
Essex UK
We seem to have agreed in the past that the E/S switch on the hydraulic box (like my 190 has) doesnt seem to make any noticable difference at all....does it on the electronic boxes?
Anonymous
The S/W on the electronic boxes makes the car a lot more sluggish , and a bit smoother. Not sure if there is any fuel advantage as i just leave it in s.
(Edited by Fuzzer at 12:38 pm on July 31, 2002)
Status
www.W140.co.uk&www.r129.co
