tpms sensor
Medntee
Midlands
w220 s class
hi
my 2012 w212 e class has tpms could any tell me if the sensors are the tyre valves or is it done through the abs
thanks
kristian
hi
thanks
kristian
I reckon if you can call up a dashboard screen with pressures for each wheel then You have sensors on each wheel . If not , then it's through the abs/wheel rotation thingy
Jkh112
Bristol, UK
E350 Bluetec estate
My w212 does not show individual tyre pressures which makes me think that mine is done by wheel diameter. Wighty’s post makes sense to me.
malcolm E53 AMG
ABS sensing a difference in wheel rotation, does work although not as accurate as sensors in the valves
daveenty
The Frozen North :(
2019 AMG S Class Coupe
If it is in the valves then they should be easy enough to spot and should look like this one: -
Excuse the filth, did an airport run late last night and not had chance to clean it yet. :(
M
Medntee
Midlands
w220 s class
thank you for all your help think mines abs
