Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI
Thank's Lost Kiwi,Pretty sure it's here:
Thank's om613, Appreciated, Have a look at my reply to Lost Kiwi hereunder, and you will see t.he reason for my question in the first place.Near to his thumb. The photo here will help:
https://www.dieselpumpuk.com/wp-content/uploads/2018/06/01.jpg
That's correct as they don't go all the way in - there's quite a but left sticking outSo I bought a dipstick from ebay, with a diamond stop mark. It is of a standard length so it can be used in any 722.6 tranny, whatever car it's in.
When I put it into my W204 tranny it hit the black diamond stop while still having a good six inches of disptick not in the tube.
I can't definitively say wether it is accurate, however I measured my levels after an ATF change from ACMS who I trust, and I knew the transmission was at 82 degrees as I had a infrared temp sensor. The reading showed just below the MAX HOT mark which would be accurate if we assume ACMS put the correct amount of fluid back in after the change.
Yes Wighty.. can't help it, been niggling at me ever since. Given the importance of having the oil at the correct level in the MB transmission. It all hinges on how accurate the dipstick is, so a "STOP" on the dipstick eliminates the guesswork. And if this is the case, it will not matter how much of the stick is hanging out from the tube. However, if the only stop is when the dipstick hits the bottom of the sump, that would be problematic due to the flexibility of the dipstick.Are you still losing sleep over all things oil level buddy ?
I'm sure with all your checking (and your MB dipstick you bourght ?) , yours is bang on the moneyYes Wighty.. can't help it, been niggling at me ever since. Given the importance of having the oil at the correct level in the MB transmission. It all hinges on how accurate the dipstick is, so a "STOP" on the dipstick eliminates the guesswork. And if this is the case, it will not matter how much of the stick is hanging out from the tube. However, if the only stop is when the dipstick hits the bottom of the sump, that would be problematic due to the flexibility of the dipstick.
Did my oil change measured with a ebay dip stick, took the car for a 50 KM run measured it again topped up a little, that was over three years ago, and changes imperceptibly. Don't worry be happy!Yes Wighty.. can't help it, been niggling at me ever since. Given the importance of having the oil at the correct level in the MB transmission. It all hinges on how accurate the dipstick is, so a "STOP" on the dipstick eliminates the guesswork. And if this is the case, it will not matter how much of the stick is hanging out from the tube. However, if the only stop is when the dipstick hits the bottom of the sump, that would be problematic due to the flexibility of the dipstick.
Up to this point and after these recent post's, Yes, I am pretty confident everything is Ok, and there IS a stop, and I am reassured about it ,......and then I read Uncle Benz's post......and now I am againI'm sure with all your checking (and your MB dipstick you bourght ?) , yours is bang on the money
Yes Uncle Benz,,,,but if it's like that, then it will be very difficult to get an accurate reading of the correct level. In the best case, you would dip it as you suggest, and after locating the correct position,then mark the flexible part at the top of the tube. ( I used a locking grommet on mine in the early days, so each dip would be the same ) remove the dipstick, clean it and do another dip. But now, I think that I will unscrew the plastic tip, and insert the chrome part into the transmission until it bottoms out, and then dip it again with the tip back in place ( or vice-versa ) and compare results. Of course one pic would be worth a thousand word's ( even more in fact in this case !!! ) showing a transmission with the sump removed, and the dipstick in place....have to see if I can find one in a local workshop.The "stop" is the bottom of the sump. It is possible to push the thing down too hard, flex the black plastic bit and obtain a false reading. It takes a bit of practice and a feel for what you are doing. When you reach the bottom it is quite an indistinct feedback on the stick, but if you stop there and then just lift a quarter inch and tap it down again gently, repeating two or three times you can feel a nice solid tap that you have reached the bottom.
