Tried a couple of small jobs, and failed.
SmartAmg
2011 E class coupe 350 CDI
While it was an OK day i tried to do a couple of small jobs, and they were not as easy as I thought. :(
Firstly, touching up a few stone chips and secondly wrapping the chrome on the boot, here's the results.
Before,
After,
20190218_133447.jpg Before,
20190218_115820.jpg After, 20190218_140155.jpg Before,
20190218_115614.jpg After,
20190218_140203.jpg Before,
20190218_115709(0).jpg After,
20190218_140144.jpg Actually having seen the photos ,the touching up isn't quite as bad as I thought, not brilliant, but a tad better, but the boot wrap, not happy at all, i took it off, you could still are the chrome around the edges, back to the drawing board.
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
Hi.
Wouldn't it be easier to remove the Chrome Strip and then Wrap it?
Binnedit
Stoke on Trent
CL500 W216
Touch Up aint too bad.
Have you seen this? Not saying to follow to the letter, but some techniques & idea's are good.
SmartAmg
SmartAmg
Hi.
Yep probably would if I knew how to get the chrome strip off.
SmartAmg
SmartAmg
M
Not too sure on your particular model, but you'll most probably have to remove the trim inside the bootlid to get to the fasteners holding it on.
Mmm, i will have a look, I've already had the inside boot trim off when I fitted the Mercedes black badge, never thought to look to see if the chrome strip came off easily, but I will now. :)
vtaylor78
Northamptonshire.
E350 CDI Coupe C207 2010 \ SLK 250 R172 2011.
If I remember rightly, getting that chrome boot trim off is a right pain.
I had a quick look when i replaced my boot badge.
You have to remove the boot locking system!! More trouble and likely hassle if it all goes “Pete Tong” so I wrapped it in situ.
John Laidlaw
Wirral
Land Rover Discovery 4
The touch up isn’t bad, you just need to keep filling and smoothing, filling and smoothing ....it’s a patience thing (not that I have any these days)- agreed on the wrap though, that’s a real shame but it will need to come off to do it properly (just don’t know how?)
AnthonyUK
Alton, Hants
C240 estate 2002
With the stone chips it is a bit of a leap of faith breaking out the wet and dry.
I tried it on the bonnet and was amazed after re-polishing the clear coat.
