Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
My Master-Mechcanic, 30 year old 2 Ton trolley jack, leaked a little from the big piston, that lifts the arm.
A Small 3” stain on the floor. it didn't drop at all, and worked perfectly.
I extended the arm , and cleaned it up with Jack oil.
Now it is bone dry , doesn't leak at all.
Left wife’s A Class jacked up for 6 hours, with the wheel on - just in case!
It didn’t drop at all. Up and down ... all seems perfect.
It seems to be perfect, but would you trust it, as it is 30 years old ???
Note. Of course I would always use axle stands if going under it. Or back it up with the new 2.5Tin jack for anything else.
I am puzzled by the fault, could a bit of dirt have compromised the “wiper seal” and thus caused a little leak from the reservoir? , and by cleaning the ram piston off, and raising and lowering it , the dirt was moved off the seal?
No problem buying a new one if safety is involved, but if my assumption is a real possibility, seems a shame to bin it.
Only thing done to the hack was emptied the old oil and put in fresh last year.
