turbo problems hissing noise
chrisy5555
Hello
My turbo blew up this week
Mercedes said they had one which had been on a car then taken off sent away and tested and came back as perfect and they said I could have it for 500 quid
I took it to my local garage to be fitted it works but has a loud hissing noise when you put ya foot down
It also hesitates before going for it at around 3000 rpm
Any ideas what's wrong with my car and if the new turbo mercedes gave me for 500 quid will be covered and who will pay the refitting charges??
rf065
Grossbritannien
Interesting, when my turbo went, Mercedes fitted a new one under warranty which they said was noisy on the road test. They ordered another new one and changed it again.
Hissing noises usually come from a split hose though, I would check the hoses and connections first.
Russ
C
chrisy5555
My car is over 3 now though unfortunatly
I thought hissing would be a hose I've had it in the past so replaced all hoses and garage checked them.
If I take it to Mercedes tomorrow do you think they could find it?
I'm starting to really hate the car now
rf065
Grossbritannien
I would take it to the dealer who sold you the turbo & see if they will check it free of charge as they have possibly sold you a duff turbo.
Who pays for what if it has to be taken off again is more of a problem. I would try to come to an amicable arrangement with them if they are willing to discuss it.
Russ
C
chrisy5555
Well I have taken the car into mercedes today and left it there
So far they said they will charge me £100.00 to diagnose the problem
they said a metal rod they supplied with the turbo wasnt fitted, the garage said they did fit it and it wouldnt cause the hissing anyway.
They also said the speed sensor in the gearbox was broken so ill need one of them.
They did say if the turbo is broken then they will see about getting me a new one under warrenty but still cant fit it for me so i would have to go back to the garage who fitting it and pay another £160.00 even though mercedes gave me a used part which had been sent off, checked and said it was ok.
rf065
Grossbritannien
I suspected they would say that, and cannot blame them for doing so.
I would have hoped they would have diagnosed whether the turbo was at faulty though for free. Even a goodwill agreement from Mercedes to pay part of the labour costs if you have to replace it again would have been a good result.
Russ
C
chrisy5555
well latest update is its been at merc all day said the speed sensor was broken, but after clearing faults its ok now??
Origional turbo hiss noise was sorted and i was charged £109.00 so off i went only to find the noise was exactly the same, so i retured to mercedes where i was told they could have another look next week, i complained and they gave me my money back but did say it could only be a hose or intercooler.
I came home and found the bottom turbo hose was hanging off so connected this properly and the hiss has gone.
HOWEVER i am not still left with another annoying problem where when you floor it it revs to 3000rpm then stops then goes again mainly in the low gears, if you catch it where it revs straight past 3000 the problem isnt there but if its pulling from 2 to 3 then it stops then goes again
Does anyone have any idea whats causing this i feel like blowing the car up now!
thanks
5pares
Suffolk
E320cdi
Has the linkage been fitted to the turbo?these have been causing problems.
Ian B Walker
Lancashire
300td
Make sure the air inlet to the air filter is connected properly. Under load if not fitted correctly it will collapse and starve the engine and turbo of air. It happened to me some time ago and by pure chance I noticed it. This was also at 3000rpm. It is easy to overlook.
