Check hazard light switch put them on and off a couple of time if the fault is still there It is probably the flasher unit itself.
You don’t say what the model is.
At a guess, a faulty relay - find the offending item in the relevant fusebox area, and replace it. If you're lucky, theres an identical relay in the car controlling another aspect, and you can test to see if its faulty by swapping them briefly.
The flasher unit is not interchangable with any other unit, it is a dual flasher half left half right and both for hazard located in the main fuse box.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
