Tyre advice
Funkyboy
Liverpool
E250 w212 14 plate
I've currently got 275/30/19 on rear of E250 AMG. I'm thinking of going to 275/35/19 for bit more on Sidewall. Anyone done this or envisage any Issues?
If you change the rears you also need to change the fronts to avoid issues with ABS, ESP and Cruise.
Noddy 99
Telford, Shropshire
2009 W211 E-Class E280 Sport Estate (OM642 3-litre diesel V6), 3x remapped, now returned to stock
I think you'd need to go down to 18" rims to keep your speedo accurate - your rolling radius will have changed.
Gazwould
C250 CDI
Holy mother , I was impressed when my C250 CDI had 255 width 18" on the back as a C63 with 18's also does .
275 :shock::shock::shock: it's not a garden roller .
As above 18's .
As above 18's .
Our SL has 275/35 19s on the rear...
Gazwould
C250 CDI
What horses and torques ?
Gazwould
C250 CDI
Yeah that's wide , similar numbers on the S14 on R34 Skyline alloys with 225 .
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Worrying about a bit sidewall.
To answer the original question more fully.
Providing you have space for the extra diameter you can go 225/40/19 front (original I'm guessing is 225/35/19) and 275/35/19 rear (original 275/30/19) without any ESP/ABS issues.
This is what the previous owner of our SL did and it works without issues.
You cannot do rears without doing fronts.
You do need to check there 8s enough room not just on the straight ahead position but also the full lock position on the fronts.
