Rick Hick
- Nov 28, 2021
- C220d AMG Line premium night edition
I have a '21 plate c220d mag line premium night edition with 19" alloys running on Pirelli P Zero run Flats. On full lock I am getting like a rubbing/ Knocking sound like the tyre is struggling to stay on the rim. When the car was delivered the tyre pressures were set at 31psi and were showing this on the mercedes me app. I've seen on the fuel flap that the pressures should be 36psi. Firstly, should the tyre pressures be increased to what is on the fuel flap or do rum flats require lower pressures and if the pressures are wrong, could this be causing the sounds I'm hearing from the front tyre? Thanks.
