Tyre Pressure Warning
TheMilkman
C220D
The tyre pressure warning light has turned on in my Mercedes c220d 2018.
I pumped to 36psi, most were 34-35 but the lights aren’t turning off.
Any ideas?
T
TheMilkman
C220D
Have you reset the TPMS?
No, I was concerned that if I do that then I could be hiding a genuine problem.
How do I know the correct psi for each tyre?
CJD
Bourne
C200 AMG Line, Premium Plus, S205 Estate, 2018
Have you pushed OK on the steering wheel?
littlebrooklyn
SW Herts
2016 A180d
If it were a problem wouldn't the warning light come back on again? We had a similar thing a couple of years ago when the same warning light was coming on, each time for the same tyre. Kept pumping it up, reset it, a week or so later it would come back on again. The tyre was quite new, appeared to be fine, but did turn out it had a slow puncture o_O
JDPEClassUK
E Class Estate E220d (2019)
Reset won’t conceal a problem. If there is a fault it will alarm again.
peterws1957
Lancashire
Yep - pumping up the tyres won't reset the warning. You have to do it manually.
Tel: 020 8863 9233
